Carcher
Jun 22, 2021Aspirant
Nighthawk X6 R8000 Drop Wired Connection
I have been struggling consistently with my wired connection dropping for a few seconds 5-10 times a day. I am using a wired connection, going through a network switch, cables are all CAT6. My router...
Jun 22, 2021Guru - Experienced User
why are you 11 versions behind on firmware?
Try updating to the latest, doing a factory reset and reinstall.
https://www.netgear.com/support/product/R8000
what modem/gateway is it connected to?
Carcher
Jun 26, 2021Aspirant
I updated the firmware and everything and I am still having the same problem. Another member of my family is having the same problem so it may be my gateway which is an xFi gateway (TG3482G).
- michaelkenwardJun 27, 2021Guru - Experienced User
Looks like a modem/router. (Gateway usually means that, often with phone support thrown in, but some people are very loose in their descriptions.)
plemans asked about that because this is a constant cause of problems.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router.Using Bridge Mode On Your Wireless Gateway - Xfinity Support
Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
