Wifeofshrek
Sep 06, 2018Tutor
Nighthawk X6 R8000 dropping internet
Good morning,
BACKGROUND - We have had this router and it has been outstanding for over 2 years - hasn't missed a beat. I have very little technical knowledge when it comes to these things, (just a...
- Sep 09, 2018
Greetings Australia,
1.0.4.18 is the latest FW available for your model. It was released in May of this year. When did it get upgraded?
I do not believe automatic update for this model was introduced until this FW version. If the router has not been reset since this upgrade, I would start with that. This will reset the router to defaults, keeping FW 1.0.4.18 installed. You wlll need to rename your wireless broadcasts and enter your passwords again.
Reset procedure
Advanced tab > Administration > Back Up Settings > [Erase] button
Note: If you have any special settings, port forwarding, static IPs etc, you can copy these down before performing the reset.
Wifeofshrek
Sep 08, 2018Tutor
Oh wait!! I logged in and found it.
Firmware version is V1.0.4.18_10.1.49
(told you I have no knowledge of these things)
shadowsports
Sep 09, 2018Hero
Reset procedure
- WifeofshrekSep 19, 2018Tutor
Thanks for your help! I have updated the router to the latest version as per your advice - thank you for your clear instructions :)
We are on holidays now for three weeks, so I won't be able to see if it has worked until we get back. I will let you know.
I really do appreciate the help received here. Fingers crossed that is all it was :)
- shadowsportsSep 20, 2018Hero
Greetings,
We didn't ask you to update your FW, we recommended that you reset the device to defaults to see if this resolves the intermittent disconnection behavior. Maybe thats what you did?. But all you need to do is reset, not reflash. Big different between these two.
Please follow up when you return from holiday.
- WifeofshrekOct 12, 2018Tutor
Hello everyone.
Just a heartfelt thank you. Yes I did the reset as suggested and the problem seems to have been fixed.
Sorry for the 'jargon' mishap. Like I said initially - I'm clueless.
