mdashwin
Apr 23, 2021Follower
Nighthawk X6 R8000 ethernet ports not working after power outage...
Hi,
My nighthawk x6 R8000 none of the ethernet ports including the cable in port is working after power outage. I have tried the factory reset. I am not able to TFTP and reload the firware as none of the ports are getting detected... Any help is greatly appreciated.
Thanks
mdashwin
1 Reply
what are the led's on it doing?
Tftp/nmrpflash work by using a static ip address to fix bricked devices.
Did you try them?
