CherylD2025
Feb 18, 2025Aspirant
Nighthawk X6 R8000 GB Speed issues
I have the latest Firmware. I have 1 GB internet at my ISP Modem-- tested at the modem. As soon as it goes through the router it drops to 220-250 MB download. Why is the Nighthawk reducing the sp...
- Feb 24, 2025
Hi All,
I purchased a Nighthawk AXE7800 RAXE300 and transferred the configuration and bingo! 1GB download speed that I pay for, no problem. It was a great pick. Happy to share that. It also allows me to go up to 2.5 GB incoming download speed in the future.
So it confirmed that my R8000 had either firmware problems or hardware problems and was end of life.
CherylD2025
Feb 20, 2025Aspirant
I will look at it. This is a work environment, with business internet. I don't use the router for WIFI and we are talking wired speeds at the router. the WIFI is run off GB switches off the network not the router. My concern is the lack of WIRED speed coming out of the router.
I will look at the models but was really looking for some recommendations on models that someone has tested.
michaelkenward
Feb 20, 2025Guru - Experienced User
So what is the R8000 doing in there? And what are these GB switches. What does the wifi come from?
As generally understood, switches do not deliver wifi. They are often "dumb" devices that let you add several devices to the network that feeds back to the router.
Disclaimer: Just another user with time on their hands.
