hayden_250
Feb 08, 2020Initiate
Nighthawk X6 R8000 not getting gigabit speeds
Hi so I recently got a nighthawk router because i was upgrading my internet to gigabit speeds and I wanted to get the best experience for it but i havent been able to get close to 1 gigabite speeds. ...
Kobutah451
May 14, 2020Tutor
I ended up having to do a complete reset and reconfig of my router to start getting the right speeds through my ISP.
I verified through fast.com, speedtest.net, and my ISPs speed test sight. All giving me aroung 950Mbps.
duggar
Jun 21, 2020Aspirant
I am having thre same problem but tried all things suggested above. but no success Can you elaborate on what wifi setting you manually configured so I can learn too.
- Kobutah451Jun 22, 2020Tutor
This issue went away after doing the most recent firmware upgrade through the automatic upgrade process.
I had called support and they were about to have me to a same version "update" of the firmware to see if there was a corruption of the current firmware. We didn't because I had done the temp fix and wasn't able to do it when I was on the phone with them.
