hayden_250
Feb 08, 2020Initiate
Nighthawk X6 R8000 not getting gigabit speeds
Hi so I recently got a nighthawk router because i was upgrading my internet to gigabit speeds and I wanted to get the best experience for it but i havent been able to get close to 1 gigabite speeds. ...
duggar
Jun 21, 2020Aspirant
I am having thre same problem but tried all things suggested above. but no success Can you elaborate on what wifi setting you manually configured so I can learn too.
Kobutah451
Jun 22, 2020Tutor
This issue went away after doing the most recent firmware upgrade through the automatic upgrade process.
I had called support and they were about to have me to a same version "update" of the firmware to see if there was a corruption of the current firmware. We didn't because I had done the temp fix and wasn't able to do it when I was on the phone with them.
- JehlertAug 15, 2020Aspirant
Just increased to gigabit wifi and the speed is verified at the modem but speed tests on everything show around 150Mbps. The router speed test shows 300-400Mbps turned of Qos seting also did a reset of the modem to factory. New firmware and the trafic meter is off. I have a cat 6 cable connected and everything is new in the past year. Netgear support wanted $90 to talk to me and was going to do a hard reset but everything else they said to do I had already tried. The internet is charter spectrum. Have done everything I can think of but am getting nowhere near speed I should be. I have verifid link speed wireless and the speed tests over wifi arent even 1/3 that number. My network has trafic so after the factory reset I left the default Network name so NOTHING was connected and tried again and still saw around 100Mbps wireless on 1 device capable of 242Mbps and 345Mbps at the router via speed test in router settings. The bottleneck seems to be between modem and router. I could use some help. I realize the wifi trafic slows things down but when I had 200Mbps service I could get 200Mbps at the router now with 940 I only get 345. I already did everything on every thread I found but am unsure how to roll back firmware. My next plan is to take the free router from charter and see if it helps.
- rinthosAug 15, 2020Luminary
Jehlert wrote:Just increased to gigabit wifi and the speed is verified at the modem but speed tests on everything show around 150Mbps. The router speed test shows 300-400Mbps turned of Qos seting also did a reset of the modem to factory. New firmware and the trafic meter is off. I have a cat 6 cable connected and everything is new in the past year. Netgear support wanted $90 to talk to me and was going to do a hard reset but everything else they said to do I had already tried. The internet is charter spectrum. Have done everything I can think of but am getting nowhere near speed I should be. I have verifid link speed wireless and the speed tests over wifi arent even 1/3 that number. My network has trafic so after the factory reset I left the default Network name so NOTHING was connected and tried again and still saw around 100Mbps wireless on 1 device capable of 242Mbps and 345Mbps at the router via speed test in router settings. The bottleneck seems to be between modem and router. I could use some help. I realize the wifi trafic slows things down but when I had 200Mbps service I could get 200Mbps at the router now with 940 I only get 345. I already did everything on every thread I found but am unsure how to roll back firmware. My next plan is to take the free router from charter and see if it helps.
To roll back firmware, the closest you can do is download the older firmware version(s) and then just use the web portal to 'upgrade' to them..
For the R8000
https://www.netgear.com/support/product/r8000.aspx#download
Then on the right below the "ReadyShare Vault" link is a "+ previous versions" section. Click on that to find old firmware versions.
- FvMcGeeSep 16, 2020Initiate
I have the R8300, just upgraded to Spectrum Gig (realy 980 down, 35 up). I had to "define my internet bandwidth" as well as use "static ip" address. The router speedtest never goes above 600MB/s. My computers on the network running speed test via ethernet cable are getting the full speed. Netgear's speed test in the router is busted. Don't trust it.
- vitaminbp1Aug 15, 2020Initiate
Honestly I gave up on Netgear. Since they want to charge you for even basic support it's not worth it.
I went to the Asus gaming router, ac5300, the controls are better and I know I'm getting the full gigabit service I'm paying for.
I also know that Asus supports their products without limitation to how old they are, so I can trust I have their support.
Netgear has lost their sense of taking care of the customer.
