hayden_250
Feb 08, 2020Initiate
Nighthawk X6 R8000 not getting gigabit speeds
Hi so I recently got a nighthawk router because i was upgrading my internet to gigabit speeds and I wanted to get the best experience for it but i havent been able to get close to 1 gigabite speeds. ...
Eich8891
Sep 04, 2021Aspirant
I really rather not buy an expensive router if the chances are that it's just firmware. With that said, what are the chances this will be resolved with firmware? Has anyone had any luck rolling back to a specific patch?
ObiWanRavioli
Sep 05, 2021Aspirant
I tried running FreshTomato for a while and that seemed to fix it. As soon as I went back to Netgear's firmware, the problem started again. Netgear really needs to fix this, this shouldn't be a problem for an expensive router like this
- Eich8891Sep 05, 2021AspirantDoes tomatoFTW work for it still? Besides that, has anyone had luck with past firmware versions?
So far my "bypass" is using QoS manual settings which as others experienced will revert to slow speeds again.
