hayden_250
Feb 08, 2020Initiate
Nighthawk X6 R8000 not getting gigabit speeds
Hi so I recently got a nighthawk router because i was upgrading my internet to gigabit speeds and I wanted to get the best experience for it but i havent been able to get close to 1 gigabite speeds. ...
Feb 17, 2022Guru - Experienced User
đ
Keep us posted on next time you see this happen and how many days/weeks it took.
Zman44 wrote:
Has a factory reset and setup from scratch been performed since last FW update? Yes. Multiple times.
Be sure your using good quality LAN cable between the ONT and Router. CAT6 is recommended. I installed all Cat 6 cable. I tested and all connections are good. Verizon also tested with same results.
Connecting desktop direct to ONT has always resulted in 900+Mbps speeds U/L & D/L (essentially Gb speed).
Good luck with the R8000.
So my slightly unused R8000 router arrived today.
Just got it connected and did some basic testing.
Router came loaded with v1.0.4.62. I didn't let it update FW. Wanted to test this out of the box first thought v76 was offered during the setup wizard.
Found 1 item that maybe a onboard/speedtest/speedtest service issue.
Speed test on the routers web page doesn't seem to seen anything near 900Mpbs on my 1Gb plan:
With a wired PC connected to the back of the router, ooklas speed test app does see over 900Mpbs on my 1Gb plan:
I'll monitor this to see if the external speed test app sees any drop in speeds over the weekend.
- FURRYe38Feb 19, 2022Guru - Experienced User
Speed check today:
- FURRYe38Feb 20, 2022Guru - Experienced User
Speed check again today:
Still rockin.
- FURRYe38Feb 26, 2022Guru - Experienced User
Mines on v62 FW.
Factory reset the router and setup from scratch, I recommend NOT enabling QoS, Armor or Circle. As these see to slow down WAN to LAN perfomances.
