aresyeah's avatar
aresyeah
Nighthawk X6 R8000: one 5G network suddenly becomes super slow
Hi!    Not sure if you guys have experience with this but thought I should give it a try.   I have two 5G networks enabled and let's call them network A and network B. Sometimes when I am usi...
  • IrvSp's avatar
    IrvSp
    Nov 17, 2018
    aresyeah, oh, you are on an R8000. On the QoS page might be what you want. On the bottom of that page is  a link, "Click here to see Bandwodth Utilization by Device and Application". Not sure I noticed that on the prior F/W, but it is on F/W V1.0.4.28_10.1.54.
    You do have to enable QoS though and that might cause Internet Speed reduction.
