Gamma111
Jul 20, 2016Aspirant
NightHawk X6 R8000 Only shows 1 SSID
Earlier this morning there were 3 SSIDs, the 2.4 GHz and the Two 5 GHz SSIDs. After coming home I noticed all the SSIDs were missing from my avaliable connections and I was forced to reset my router....
- Jul 28, 2016I just purchased a new Netgear X6 R8000 router and ya been working. Looks like my previous one was broken or something. Current one is working perfectly fine.
Retired_Member
Jul 21, 2016push reset until power led flashes and use default settings and test
JamesGL
Jul 28, 2016NETGEAR Employee Retired
Hi Gamma111,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
