Silyus
Nov 28, 2021Tutor
Nighthawk X6 R8000 ping spikes and DNS problems
I bought a Nighthawk X6 R8000 router (Firmware Version V1.0.4.76_10.1.82) for my domestic use. I've a raspberry PI, a NAS (with 2 ethernet connections), and a smart tv connected to the LAN and tw...
Nov 28, 2021Guru - Experienced User
There are known issues with the 8000 series FW. Best to revert back to what had been working until NG fixes this.
Silyus
Nov 28, 2021Tutor
By revert back you mean return the router?
What I had before was the stock router from my ISP which is...well....not that good.
I bought this router on a solid deal, my options now are troubleshoting these issues, return the router and roll the dices again on a new one or wait for a fix from NETGEAR (assuming it's indeed a FW problem and not an HW problem).
- FURRYe38Nov 28, 2021Guru - Experienced User
No, revert back FW version to what had been working before you updated the FW.
- SilyusNov 28, 2021Tutor
I updated the FW first thing when I unboxed. Rookie mistake, I know, but I never used NG so I assumed the latest was the best version.
Is there a reliable source where I can find the optimal FW version for each router?
IF it was new and out of the box, you can go back to first version of FW:
https://www.netgear.com/support/
Input the router model and you'll find all fw versions listed.
