SK2022's avatar
SK2022
Tutor
Feb 26, 2022
Nighthawk X6 R8000 Problems
After the latest firmware update a couple of months ago (Firmware Version V1.0.4.76_10.1.82) I sharted having two major problems with the router: 1. Every other day the DNS breaks down, and I have ...
  • FURRYe38's avatar
    v.62 seems to be the best version for now.
    Hasselby wrote:
    Been around 48 hours since downgrading the firmware...zero issues. I did not see my DNS issue recurring again through multiple computers at home. I had to refresh multiple times whenever I loaded a new webpage or add a new tab, but everything is smooth sailing right now.
