SK2022
Feb 26, 2022Tutor
Nighthawk X6 R8000 Problems
After the latest firmware update a couple of months ago (Firmware Version V1.0.4.76_10.1.82) I sharted having two major problems with the router: 1. Every other day the DNS breaks down, and I have ...
- Mar 07, 2022
v.62 seems to be the best version for now.
Hasselby wrote:
Been around 48 hours since downgrading the firmware...zero issues. I did not see my DNS issue recurring again through multiple computers at home. I had to refresh multiple times whenever I loaded a new webpage or add a new tab, but everything is smooth sailing right now.
Mar 04, 2022Guru - Experienced User
Ive pass this onto NG. Im seeing DNS issues on v.76, I recommend rerverting back to v.62 for now.
Hasselby
Mar 05, 2022Guide
Thanks for the tip. I have had this DNS issue for months, and I thought it was my ISP.
Just downgraded to v.62, going to update here if I see any issues for the next few days.
- FURRYe38Mar 05, 2022Guru - Experienced User
v.76 is too bad but I found the DNS issue, minor, and WiFi Smart Connect seems to slow down the WiFi performance. Disabling it brings speeds back. Also Traffic Meter seems to slow things down as well. :smileyfrustrated:
- HasselbyMar 06, 2022Guide
