michaelwong
Jul 14, 2017Aspirant
Nighthawk X6 R8000 Router Firmware Update Issue
There is no way for my router to update the firmware. Tried Router Update / A router firmware upgrade is avaliable with no luck. Please help. Thanks.
- Jul 16, 2017
Hi michaelwong,
Make sure to unzip the downloaded file. The file that should be loaded on the router has the .chk extension.
michaelkenward
Jul 15, 2017Guru - Experienced User
Hard to understand what you are saying without the picture that has yet to arrive.
The user manual tells you how to do a manual firmware flash:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
See page 133.
- michaelwongJul 15, 2017Aspirant
The firmware downloaded from Netgear support should be valid. However, the update is not working.
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi michaelwong,
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi michaelwong,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
