michaelwong
Jul 14, 2017Aspirant
Nighthawk X6 R8000 Router Firmware Update Issue
There is no way for my router to update the firmware. Tried Router Update / A router firmware upgrade is avaliable with no luck. Please help. Thanks.
- Jul 16, 2017
Hi michaelwong,
Make sure to unzip the downloaded file. The file that should be loaded on the router has the .chk extension.
michaelkenward
Jul 15, 2017Guru - Experienced User
Hard to understand what you are saying without the picture that has yet to arrive.
The user manual tells you how to do a manual firmware flash:
>>>>> R8000 | Product | Support | NETGEAR <<<<<
See page 133.
michaelwong
Jul 15, 2017Aspirant
The firmware downloaded from Netgear support should be valid. However, the update is not working.
- JamesGLJul 16, 2017NETGEAR Employee Retired
Hi michaelwong,
- JamesGLJul 19, 2017NETGEAR Employee Retired
Hi michaelwong,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.- michaelwongJul 27, 2017Aspirant
Is there any other way to perform update of firmware?
- michaelwongJul 23, 2017Aspirant
Tried unzip the zip file. It is not helping.
- michaelkenwardJul 24, 2017Guru - Experienced UserYou seem to be going through several updates in one leap. You are five behind the latest. It should work, but you could try using an intermediate firmware. First try the one after your current version.
