MCWB
Jan 18, 2016Aspirant
Nighthawk X6 R8000 Schedule
I purchased this router with the intentions of increasing my wifi speeds. I have the black comcast package (180 Mbps) but I am only getting arond 50 from this router. I was told I could get more whic...
- Jan 20, 2016
Try turning off QOS. You really don't need it with the speeds you can get.
JamesGL
Jan 20, 2016NETGEAR Employee Retired
Hi MCWB,
When you connect your computer directly to the mode, what is the speed?
What is the firmware version of the router?
Have you tried changing ethernet cables?
MCWB
Jan 20, 2016Aspirant
Hey,
When I connect my computer directly, the speed is 180Mbps.
The firmware version is 1.0.3.4.
My ethernet cables are CAT5e so I didnt see any point in changing them.
