MCWB
Jan 18, 2016Aspirant
Nighthawk X6 R8000 Schedule
I purchased this router with the intentions of increasing my wifi speeds. I have the black comcast package (180 Mbps) but I am only getting arond 50 from this router. I was told I could get more whic...
- Jan 20, 2016
Try turning off QOS. You really don't need it with the speeds you can get.
MCWB
Jan 20, 2016Aspirant
I have QOS running but I didnt change anything but the SSID and password. Everything is the same.
LeeH
Jan 20, 2016Prodigy
- Retired_MemberJan 20, 2016
What mode @ 289 I connect @ 180 and tranfer @ 18MBps
@ 1300 I connect 877.6 and tranfer @ 70MBps
My speed test are 126MBps on all settings. I have AC clients so these mean nothing in comparison to non AC clients. AC is ALWAYS on and the rates go up as the channel bonding goes up as long as client has more than 2 antennas to realise 1300
If he's topped at 50 then make sure WMM is enabled and using WPA2 Or his client is a older version which limits streams.
- MCWBJan 20, 2016Aspirant
A couple of things,
1. Im a woman.
2. I will double check all of these things later today.
3. I think I will just purchase the adapater and see if helps.
