cocofire
Jul 06, 2018Aspirant
Nighthawk x6 r8000 second 5GHz channel isn't showing on my computer but is showing on my phone
I'm trying out having the 5GHz-2 channel but when I try to find it on my computer it doesn't show up but it does on my iPhone 6s. I can see the 5GHz-1 fine but for some reason 5GHz-2 doesn't show up....
- Jul 07, 2018
It was a good work around for it not working on the autumn update but it didn't find the second 5GHz for some reason. I recently changed my wifi adapter and that one was able to work.
cocofire
Jul 07, 2018Aspirant
I don't have SMART CONNECT on. My brothers PC was able to see and connect to it and my phone. I heard about the problems and it happened to me about the the T6e not working on the new WIN 10 update and all I did was change the PCI-E slot and it worked for me after that.
