brous47
Mar 07, 2024Aspirant
Nighthawk x6 r8000 seems to be throttled
Just updated my ISP to 1Gbs, however I am not even getting half of that. Just called the ISP, and they are seeing over 1Gbps from the modem. I hardlined into the modem and saw the same thing, so some...
Mar 07, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Try using Ooklas installable speed test app on the PC.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
- brous47Mar 07, 2024Aspirant
Oddly enough, the modem doesnt seem to have a manufacturer on it (its from Charter/Spectrum) Model number ET2251. They sent the modem when I upgraded (~2 weeks ago), I am using their supplied CAT5e cable to connect the router to the modem, but I can go get a 6.
I have rebooted everything (pc, router, and modem) several times since the new modem came in and since the call with the ISP.
I have not done a factory reset of the router, I guess I can try that after I log off of work for the day
- FURRYe38Mar 07, 2024Guru - Experienced User
Ok.
Thats a Hitron model modem.
Something to try, connect directly to the back of the ISP modem with a wired PC and run a speed test with out the router in the mix.
Try a reset on the router when you can.
- brous47Mar 10, 2024Aspirant
Factory reset did nothing in terms of improvement, still less than half the speeds of connecting directly to the modem gets me. made sure the factory reset didnt turn on any erroneous parameters/settings not sure what else can be done other than getting a newer model
