brous47
Mar 07, 2024Aspirant
Nighthawk x6 r8000 seems to be throttled
Just updated my ISP to 1Gbs, however I am not even getting half of that. Just called the ISP, and they are seeing over 1Gbps from the modem. I hardlined into the modem and saw the same thing, so some...
brous47
Oddly enough, the modem doesnt seem to have a manufacturer on it (its from Charter/Spectrum) Model number ET2251. They sent the modem when I upgraded (~2 weeks ago), I am using their supplied CAT5e cable to connect the router to the modem, but I can go get a 6.
I have rebooted everything (pc, router, and modem) several times since the new modem came in and since the call with the ISP.
I have not done a factory reset of the router, I guess I can try that after I log off of work for the day
Mar 07, 2024Guru - Experienced User
Ok.
Thats a Hitron model modem.
Something to try, connect directly to the back of the ISP modem with a wired PC and run a speed test with out the router in the mix.
Try a reset on the router when you can.
- brous47Mar 10, 2024Aspirant
Factory reset did nothing in terms of improvement, still less than half the speeds of connecting directly to the modem gets me. made sure the factory reset didnt turn on any erroneous parameters/settings not sure what else can be done other than getting a newer model
- FURRYe38Mar 10, 2024Guru - Experienced User
After the factory reset did you set up from scratch using a wired PC and web browser or Nighthawk mobile app?
Change out lan cables between the modem and router and wired PC and router to be sure? CAT6 is recommended.
Speed testing with Ooklas installable speed test app?
yup, my PC is always hardlined into the router. I changed my modem's supplied cable to a CAT8, no difference, same with the cable from the router to my PC. tried the ookla speed test, speedtest.net, and the speedtest in the netgear GUI (which was the lowest of the 3 by over 50%, which I thought was odd)
