CristosJunk
Aug 13, 2024Follower
Nighthawk X6 R8000 set to AP mode cannot connect to NTP server. How to fix that?
I have a Nighthawk X6 R8000 set to AP mode (IP address 192.168.1.4). It is wired to the primary router which is a Verizon FiOS CR1000B router (192.168.1.1). I have a hard drive attached to the Nighth...
michaelkenward
Aug 14, 2024Guru - Experienced User
In AP mode, the R8000 doesn't have much control over things.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
In my case, an R7800 in AP mode works just fine when it comes to NTP settings. I am using the Netgear default and my local time zone.
Where did you set the IP address for the R8000? Fixed on the R8000 or reserved on the FiOS CR1000B?
Just another user with time on their hands.
