AnthonyL
Nov 24, 2019Aspirant
Nighthawk X6 R8000 slow after Firmware update to 1.0.4.46
Long story short, Firmware version 1.0.4.46 reduced throughput on my Netgear Router by half! Rolling back to 1.0.4.28_10.1.54 resolved the issue. Long story. I was experiencing slow internet con...
Nov 24, 2019Guru - Experienced User
I've read of several people having issues with the newest firmware on the R8000. Most have been resolved with the downgrade to a version getting rid of armor. Hopefully they're working on a fix.
AnthonyL
Dec 01, 2019Aspirant
Are you kidding me? You're offering my solution back as a solution?? Not sure you have any clue what you are doing or you are just trying to get poster points. Well, unless you are a bot. Either you didn't read more than the first 3 lines or you have no business trying to moderate a solution. Shake my head/facepalm.
