kilthor
Apr 26, 2022Aspirant
Nighthawk X6 R8000 Slow Internet Speed
Anybody else having issues with speed after the firmware upgrade to 1.0.4.84 that just came out?? I have 1GB internet speed and before the firmware upgrade speed test would show between 920mb and 96...
Apr 26, 2022Guru - Experienced User
what modem is it connected to?
did you try a factory reset? sometimes that helps after a firmware change.
If it doesn't, I'd simply downgrade the firmware.
