kilthor
Apr 26, 2022Aspirant
Nighthawk X6 R8000 Slow Internet Speed
Anybody else having issues with speed after the firmware upgrade to 1.0.4.84 that just came out?? I have 1GB internet speed and before the firmware upgrade speed test would show between 920mb and 96...
Apr 26, 2022Guru - Experienced User
Be sure to not enable Traffic Meter. I this slowed speeds down.
kilthor wrote:
Anybody else having issues with speed after the firmware upgrade to 1.0.4.84 that just came out?? I have 1GB internet speed and before the firmware upgrade speed test would show between 920mb and 960mb download speed. After the upgrade it now shows 230mb-250mb. All advanced features such as QOS, parental controls static routes, etc....are all turned off. Is this a known issue with the firmware? I have plugged directly into the modem and I get the 900mb+ speed.
