kilthor
Apr 26, 2022Aspirant
Nighthawk X6 R8000 Slow Internet Speed
Anybody else having issues with speed after the firmware upgrade to 1.0.4.84 that just came out?? I have 1GB internet speed and before the firmware upgrade speed test would show between 920mb and 96...
kilthor
Apr 28, 2022Aspirant
Factory reset is an absolute last resort. I did find the issue. I had to uncheck Access Control. Netgear needs to fix their routers firmware. There is no good reason that having access control checked should slow speeds from 900+MB to 250MB. This leaves my network extremely vulnerable as I cannot decide to allow or block a device. This should be considered HIGH priority to correct and maybe a defect in the product.
Apr 28, 2022Guru - Experienced User
Access Controls do no effect being vulnerable.
Please make contact with NG support and let them know what your experiencing. The more they know the more apt they will get it fixed. https://my.netgear.com/support/contact.aspx
