SuperKris
Dec 29, 2020Tutor
Nighthawk X6 R8000: Slow performance trough WAN ports. Approx 250-300mbps MAX
Hi All, I just upgraded my internet from 100mbps (cable) to 1gbps (glassfiber). I also got a new router with all the fiber materials. It works good, and i get approx 920mbps. However, when try to...
- Dec 29, 2020
It wasn't until recently that the cpu's on consumer devices are getting powerful enough to do traffic inspection and pass the traffic at full speeds. And even though the R8000 seems pretty new and fancy, its actually a 4 year old device. In the world of arm processors, 4 years was quite a bit of advancement.
Dec 29, 2020Guru - Experienced User
since upgrading to fibre, did you factory reset the router and reinstall it?
That's where I'd start.
also, during the install make sure to leave disabled: qos, traffic monitoring, access control, and parental controls.
Don't enable these processes.
SuperKris
Dec 29, 2020Tutor
plemans Thanks for your reply. I did not do a factory reset yet but i did cycle the power many times, and did a firmware update just a few days ago.
As far as i can tell QoS, traffic monitoring, access control, and parental control are all disabled.
- plemansDec 29, 2020Guru - Experienced User
The reason sometimes a factory reset can help is qos/traffic monitoring/etc all slow speeds because it has to place a burden on the cpu to instpect the traffic. And sometimes even though disabled/rebooted, the cpu still inspects traffic. A factory reset can kick it back in so traffic is automatically forwarded. its worth trying.
Just make sure not to reinstall using a backup configuration. Basically factory reset, install the mimimum that you need (ssid/password/internet connections) and then speedtest and see where you're at.
- SuperKrisDec 29, 2020Tutor
plemans damn.... I triple checked it and found traffic monitoring was indeed still enabled. I disabled and it broke the internet connection. After a few reboots it now working again and i get now get approx 910mbps down so thank you!
I'm however still a little bit disapointed that a +$ 200,- router looses 70% of its WAN bandwith if any options are activated...
I hope the speed stays a solid 900mbps!
