mjohnson24's avatar
mjohnson24
Nighthawk X6 R8000 slow speeds wired and wireless any device
When i plug my computer into my cable modem then i get up to 300mbs down but when i plug into my routyer i only get maybe 30-40 down max. Have rolled back firmware to previous version and nothing. En...
  • mjohnson24's avatar
    mjohnson24
    Jan 30, 2022
    UPDATE:
    I found the issue! It was my mistake and I completely forgot about what I did. I went from my cable modem to a UPS battery backup then to my netgear router. Problem is my UPS battery backup was only capable of slow speeds. Thats why.
    Thanks for the help and all! Appreciate it and your time.
