jkexel
Sep 14, 2022Tutor
NightHawk X6 R8000 spits out "Invalid IP address. Please enter it again."
I have a NightHawk X6 R8000 Firmware - V1.0.4.84_10.1.84 I have a weird error message while trying change the 2.4 Ghz channel. "Invalid IP address. Please enter it again." comes up when I tr...
Sep 15, 2022Guru - Experienced User
What browser are you using? Happens with other browsers?
Does this happen if you set the router IP address pool to default of 192.168.1.1 and do same thing?
