jkexel
Sep 14, 2022Tutor
NightHawk X6 R8000 spits out "Invalid IP address. Please enter it again."
I have a NightHawk X6 R8000 Firmware - V1.0.4.84_10.1.84 I have a weird error message while trying change the 2.4 Ghz channel. "Invalid IP address. Please enter it again." comes up when I tr...
Sep 15, 2022Guru - Experienced User
What browser are you using? Happens with other browsers?
Does this happen if you set the router IP address pool to default of 192.168.1.1 and do same thing?
jkexel
Sep 15, 2022Tutor
I am using Firefox, I will try another browser and if that does not do it, a factory reset when I have the time.
Thanks
