IT4IT's avatar
IT4IT
Nighthawk X6 R8000 suddenly blocking all access
It can be a go incidence but since I have a USB3 SSD connected to the USB3 port the connection gets lost after a while. Sometimes a day but also after several hours. Meaning I can not connect to ...
  • IrvSp's avatar
    IrvSp
    Nov 05, 2018
    Does the SSD have its own power supply? If not, that could be the problem? That it works on USB 2.0 might be because it draws less power operating that way? I'd be pretty sure that drive isn't on the Compatibility list.
    To ensure the hardware isn't a problem, I'd get a drive that is on the Compatibility list try that and see if it works. Also any cheap flashdrive that is USB 3.0 should work and you can try that.
    Here is the LIST from Aug. 30th this year and it isn't very long of KNOWN TESTED drives. Not on the list (and not broken down by USB 2/3) then you might not have a 'case'.
