rick0518
Jul 05, 2019Aspirant
Nighthawk X6 R8000 wifi 5g second not working
Hi all today i found my second 5g wifi radio not working , i can't found my second 5g wifi, 2.4g / 5g first is working.. but 5g second not working. please help
- Aug 12, 2019
Kronvrak, you have a HOT FIX, https://kb.netgear.com/000061046/R8000-Firmware-Version-1-0-4-40-Hot-Fix. At one point it was put up suggesting one update to it. That has since been removed.
Go back to V1.0.4.278, might solve the problem for you.
rick0518, Dpw___, if you are on firmware 1.0.4.40, I suggest you go back as well.
Dpw___, I recall seeing this before, "There is a message about radar conflicts and no DFS channels availale", suspect the actual message was 'This DFS channel is not allowed, the Radar was detected before'.
Some attributed it to an old F/W before V1.0.4.28, others say just change the 5-2's channel will fix it?
You can Google the message I guess? This also could be a function of where you live, for instance the 5-2 Ghz SSID will not show up in Japan. The do not allow it. See https://en.wikipedia.org/wiki/List_of_WLAN_channels. R8000 should be showing channels 141-161 which is legal. What channel are you on?
Jkitch21
Aug 15, 2019Aspirant
Hello, I had the same issue occur last night. The 5G band went out, and only 2G signals were active.
When looking at the Genie, bith 5G bands were listed as 2G, but could not be changed.
The fix (and apologies, I am at work).
I connected via IP address: 168.192.1.1
Sign in and go to the advanced tab. At the top, uncheck the first box. This basically is an auto setting, but when once unchecked you can then scroll down and rename your 5G and 5G2 to what they were previoulsy. Save.
These bands were no visable and active on all devices, and using the genie.
What was odd, as we did the firmware update ~two weeks ago, with no issues, so not sure what occurred.
Edandkelly
Sep 15, 2019Aspirant
Anyone has an update how to get my second 5g working again?? I.t wants to charge $80 to gic a problem they caused after I updated thru the nighthawk app. Please assist anyone
