Imperialsalsa
Aug 07, 2023Aspirant
Nighthawk x6 r8000 Wifi issue
I have a Nighthawk x6 r8000. Firmware is up to date. Using starlink. Wifi is showing off in the netgear router menu but the physical lights on the router are lit up. I have reset the router I have...
Aug 08, 2023Guru - Experienced User
When you pushed the wifi on/off button, did you hold it for at least 2 seconds?
