Imperialsalsa
Aug 07, 2023Aspirant
Nighthawk x6 r8000 Wifi issue
 I have a Nighthawk x6 r8000. Firmware is up to date. Using starlink.  Wifi is showing off in the netgear router menu but the physical lights on the router are lit up.  I have reset the router  I have...
Aug 08, 2023Guru - Experienced User
When you pushed the wifi on/off button, did you hold it for at least 2 seconds?
Imperialsalsa
Aug 09, 2023Aspirant
Yes
- DexterJBAug 13, 2023NETGEAR Moderator
Hi Imperialsalsa , if you're still experiencing the issue. We recommend that you reach out to our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/about/contact-us/
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
