halem22
Jan 03, 2021Tutor
Nighthawk X6 R8000 wifi login fails
After last firmware upgrade, randomly, most of my devices can't loging to the WiFi. Error is "Wrong Password" However, password is the smae. I bounce the router and login as admin and the passw...
halem22
Jan 04, 2021Tutor
Been there and done that. Only thing that works is rebooting the router.
Jan 04, 2021Guru - Experienced User
done which?
The factory reset or forgetting the network?
Have you tried downgrading the firmware a version?
- halem22Jan 11, 2021Tutor
As I replied before BEE THERE DONE THAT. ALL OF THE ABOVE. Even reset the IP stack on the some devices. This forum is not worth the time. Wont be back.
