Mamasydow
Jul 09, 2021Follower
Nighthawk x6 r8000 will not connect to devices
I can not get ANY device to connect! There is interent. I have done all the power down wait two minutes and power up. Still acting the same. The lights that normally on, with the numbers 1,2,3,4 are not flashing.
1 Reply
1. What modem/gateway do you have?
2. what firmware is on the router
3. what are all the led's doing? (blinking, solid, color, etc)
4. Did something change? What caused this to start?
5. did you try a factory reset? push and hold reset for 7-15 seconds while its powered on
