rariz73's avatar
rariz73
Nighthawk x6 r8000 will not connect
I moved now my router will not connect. I've tried everything on this forum. All lights are on (white). I'll connect another router (different brand) and it works fine. I need help.
  • plemans's avatar
    What are you connect it to?
    modem/gateway model number?
    Firmware on the router?
      • plemans's avatar
        What gateway is it connected to?
        You're on old firmware (really old). I'd recommend updating to 1.0.4.62 of the firmware over a hardwired connection, then factory reset, and do a clean install (not froma backup)
