Ibaroj
May 27, 2023Tutor
Nighthawk X6 R8000 with access points X6S EX8000 - guest SSIDs
I set up the router with Smart Connect enabled, so all 3 bands use the same SSIDs. But the guest network on the router does NOT offer this option and does not allow me to use the same SSID for more t...
- May 27, 2023Nope
microchip8
May 27, 2023Master
Nope
- IbarojMay 27, 2023Tutor
In that case, if I don't want so many networks appearing, I can either (a) shut off two of the guest radios in the router or (b) shut off all the radios in the router and wire another access point not far away to handle that area, or (c) buy a new router. Any other options?
For (a), would there be any problem with the wired access points accepting guest connections on any of the bands while the router they connected to doesn't? I would assume it's ok because once the client device is connected by wifi, it's all wired.
I thought I would get the most compatibility by buying the same Netgear series for router and points. I guess not!
