Ibaroj's avatar
Ibaroj
Tutor
May 27, 2023
Nighthawk X6 R8000 with access points X6S EX8000 - guest SSIDs
I set up the router with Smart Connect enabled, so all 3 bands use the same SSIDs. But the guest network on the router does NOT offer this option and does not allow me to use the same SSID for more t...
