rameshav
Oct 28, 2021Follower
Nighthawk X6 R8000
Firmware: v1.0.4.76 Model - R8000 I see that my router is only allowing 16 devices at the max, in both 2.4GHZ gn 5GHZ, together(Combined). Any additional devices, router is saying, no internet.
Oct 28, 2021Guru - Experienced User
A little more info about your system is needed.
1. what modem/gateway do you have?
2. when did this start?
3. have you tried a simple factory reset and reinstall (don't use a backup to install)?
