Hodgiee
Jan 30, 2022Follower
Nighthawk X6 R8000
Isn't letting me login with my Security Questions. Keeps saying informtion doesn't match. I just want to log in getting frustrated please help
Problem with the password recovery feature is that if you didn't set it up (or don't get answers correct) there isn't a correct response and it just circles.
If it doesn't work and you don't know the password for the router, you'd have to factory reset to get back in.
Push and hold reset for 7-15 seconds while powered on and then reinstall the router.
Please move this thread to the Nighthawk Router forum. Thank you.
