TCart
Mar 24, 2024Aspirant
Nighthawk x6 R8000
No internet connection although all lights are on (white lights). Netgear is receiving power, but Netgear not showing up as as available devices in my network and not connecting to internet. Have...
Kitsap
Mar 24, 2024Master
TCart wrote:The Zyxel model # is EMG6726-B10A.
Thanks for your detailed instructions on the restart. I will give this a try.
This is exactly why I asked for the model number. As near as I can tell your EMG6726-B10A is a combination Wi-Fi router. When you connect your R8000 downstream, you have a double NAT configuration. Lots of problems with that situation. See here: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
Why are you connecting your R8000 Wi-Fi router downstream from your Zyxel Wi-Fi router?
Have you tried to configure your R8000 as an access point?
What device, brand and model number, is upstream that provides internet to your Zyxel EMG6726-B10A?
TCart
Mar 25, 2024Aspirant
I have not tried to configure as Access Point, but have done everything else I can think of. It wasn't an access point before the storm, so not sure why it isn't working now. Thanks for your help. I'm closing this request at this time.
