SSharp35
Jan 27, 2021Tutor
Nighthawk X6 router
Can my Nighthawk X6 router be connected to the Nighthawk 6 Mesh system?
- Jan 27, 2021
AC3000 is a speed. Not a model.
And multiple routers go by x6 and x6s. It as well isn't a model number.
so an actual model number helps with identifying the router.
Same with mesh. netgear has multiple mesh 6 systems.
Which again is why the model number helps.
The label has the actual model numbers on them.
Be either way, the router won't mesh with the mesh system. You can use it with it as I described prior but it won't function as part of the mesh.
SSharp35
Jan 27, 2021Tutor
I gave the model number where it asked for it in the form, but here it is again; AC3000 Nghthawk X6 Tri-band WiFi Router. The Mesh system is Nighthawk Mesh WiFi 6 System.
Thanks
Jan 27, 2021Guru - Experienced User
