Donncha
Aug 20, 2024Aspirant
Nighthawk X6 Smart Wi-Fi Router (R8000) - AC3200 - much slower than modem
I have 600 mbps upload/download speed fiber optic service. When i connect a PC directly to the modem I get >600mbps service. When I connect the modem to my router then hard wire to the router I...
Aug 20, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try a factory reset and setup from scratch along with powering OFF the ISP modem for 30 seconds then back ON.
After the router is set back up with a web browser and wired PC, run a speed test using Ooklas installable speed test app.
Don't enable any Access Controls, Armor, SPC or Traffic Meter. These will degrade the speed results.
Donncha
Aug 21, 2024Aspirant
What Firmware version is currently loaded? v1.0.4.84
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? NOKIA XS-010G-Q
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. As I stated earlier, all LAN cables are new, tested CAT6 cables.
I did the factory reset and confirmed I had all the additional features turned off. I had improvedspeed when I connected directly up to a LAN port, got the same speed as my ISP states is in my plan. WiFi speed lower , about 50% or less, even when my PC was right next to the router. Maybe that is normal and expected.
