bajen21
Oct 11, 2019Aspirant
Nighthawk X6
Hello.Updated my r8000 with latest firmware.My speed went down to about 100 to 150 Mbps.It should be 450-500.After many factory resets i tried to downgrade firmware.Now everythings fine again.Next up...
- Oct 12, 2019
Micheal,
Thanks for your reply. I posted solution in another thread:
michaelkenward
Oct 12, 2019Guru - Experienced User
Wifi or wired?
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems, especially on the wifi front.
