JCtheWizard
Jan 28, 2021Aspirant
Nighthawk X65 does not connect through http://routerlogin.com
The model R8000P os NOT the model number on the router - however, the correct model number did not take in the system. Here is the story: I’ve just installed a new Nighthawk X65 AC3600 Model R79...
michaelkenward
Jan 29, 2021Guru - Experienced User
You would do better to ditch any mobile app and to use a direct wired connection with the browser graphical user interface (GUI).
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Look for the model number on the label on the device.
You may have done this already. I can't tell from your message.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk WiFi Routers
