JDFly
Oct 12, 2022Aspirant
Nighthawk x6R8000 Internet Port Dead?
Netgear Nighthawk Support Hello all, New to the group but have been doing a lot of reading. Thanks to all supporting! My XR8 router just died after 2+ years of service. Wondering if it is toast o...
JDFly
Thanks Furry.
The modem is live and has internet from ISP. I can access internet direct through modem and I have tried a dozen CAT5 cables and made new T-568A, T568B and a crossover cable using CAT5 and RJ45 connectors.
Router is running V1.0.4.84_10.1.84
I picked up an Orbi 1.2GB router and satellite beacon just to get live again and it functions with no issues.
Just using router ATM. Keeping receipt for possible return if I can get R8000 live or there is a better solution.
House is ~3500sqFt,
Garage, wood, brick, concrete and vinyl siding is 250’ away and we try to feed signal to the lake -75’ directly opposite garage.
House is ~3500sqFt,
Oct 12, 2022Guru - Experienced User
Ok. I presume the R8000 has a bad port. Probably a hardware fail.
- JDFlyOct 12, 2022AspirantBad port is what I was thinking but not wanting.
If it is the Port which is dead, any viable, Out of Warranty work arounds, repairs, favours from deities that can bring it back to life?
Replace Port?
Reroute LAN Port to act in place of Dead WAN PORT?
Any suggestions for replacement?- FURRYe38Oct 12, 2022Guru - Experienced User
Quick idea, Might try to see if there is a Mirror WAN to LAN port 1 under the routers IPaddress/debug.htm. Possible if this feature is there, possible LAN port 1 could work as WAN port...
- JDFlyOct 12, 2022AspirantThere is a Mirror WAN to LAN1 radio button option directly in IP/debug.htm in web browser.
However, there is no save function on the page.
This button does not appear to be available in the Nighthawk app or when accessing router settings through browser. Trying to attach screen shot…
Thanks again
