Loudon
Apr 17, 2023Aspirant
Nighthawk X6S AC-4000 - no internet access
I have an AC-4000 that has functioned well for about 3 years. We recently had a very close lighting strike; our neighbor’s house was slightly damaged, but we only experienced a loss of internet conne...
Apr 17, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed? Press the reset button in back for 10 seconds then release. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
- LoudonApr 18, 2023Aspirant
FURRYe38 and Plemans, thank you for the response. Basically, everything that you suggested has been tried with the exception of the IP change, which I can’t do since I can’t communicate with the router.
We’re doing fine on the old (previous) router for now. I’ll order another Nighthawk today or tomorrow. Thanks again.
- michaelkenwardApr 18, 2023Guru - Experienced User
You never did say what the router was. (R8000P from around five years ago?) But my guess is that it doesn't matter.
There's nothing you can do to protect from lightning strikes. (Been there, done that.)
Surge protectors are fine for transient voltage spikes, but not for a megavolt shock that lasts for nanoseconds.
Do Surge Protectors Protect Against Lightning?
That's just one of many along the same lines.
- plemansApr 18, 2023Guru - Experienced User
We still don't know what your actual setup is.
It might not be a router issue.
It might just need a reset or proper settings to connect to the modem.Or they could be bad. But without details there isn't much to go off.
