shicks28532
Sep 12, 2022Aspirant
Nighthawk x6s AC 4000 Tri-Band This site can’t be reached DNS address could not be found
Checking the connection Checking the proxy, firewall, and DNS configuration Running Window s Network Diagnostics ERR_NAME_NOT_RESOLVED
Sep 12, 2022Guru - Experienced User
What model router do you have? R####?
Is IPv6 Auto enabled?
shicks28532
Nighthawk x6s
model R8000P
A4000 Tri-band Wifi Router
Firmware version 1.4.388.1.3.50
- FURRYe38Sep 12, 2022Guru - Experienced User
Please don't post serial numbers in public forums for security reasons. Thank you.
- shicks28532Sep 12, 2022Aspirant
internet cat 5 cable
NightHawk: R8000P
Wifi Router
- michaelkenwardSep 13, 2022Guru - Experienced User
NightHawk: R8000P
Wifi Router
FURRYe38 asked about the modem/gateway that sits between the router and the Internet.
Unless you have the optical equivalent, an Optical Network Terminator (ONT) or some other exotic device, no modem = no internet.
This can be an important factor. Some modems are also routers. Which can cause problems.
