Mark1955
Dec 05, 2021Aspirant
Nighthawk X6S AC3000 MU-MIMO Smart Wi-Fi Router (R7960P) Firmware Update Failure
I have a router running firmware version V1.4.1.44_1.3.5 and am attempting to update to the current version R7960P-V1.4.2.84_1.3.42 and following the instructions on the Netgear website it fails. I ...
Mark1955
Furrye38,
Tried this and the same result. When I select the file and select it to run, it seems to run for about 5-10 secs and then the router will reboot. Is does take a fair amount of time for it to refresh the screen but it does not display any failures, only shows that the same version is still installed. I am downloading a TFTP client and will try it that way to see if I can at least validate that the file is uploading without issues and let you know.
Mark
Dec 05, 2021Guru - Experienced User
Let us know how it goes.
What browser are you using?
Wonder if you put yours in wireless bridge mode, update FW then back to router mode, if it would work.
- Mark1955Dec 05, 2021Aspirant
When I use the client, it sits at block #0 and does nothing at all, I tried using both port 1 and port 4 with my connection to the router and nada. You suggest flipping to wireless bridge mode.....where is that located :) as I will try anything to see if I can get past this...
Mark
- FURRYe38Dec 05, 2021Guru - Experienced User
And you did set a static IP address ON your wired PC as well?
Try https://github.com/jclehner/nmrpflash as well.
Wireless bridge mode is under advanced tab/Advanced settings/Router Mode. You'll see Router/AP and Bridge options here. If you set up a bridge mode, besure to input a STATIC IP address for the mode. I'd use 192.168.1.60. You don't have to actually have it connect to anything, just use a static so you'll have access to the web page while in bridge mode. You'll need to se a static IP on your wired PC, something like 192.168.1.59
Gotcha.....I had set the wired PC with 192.168.1.10 and had everything disconnected from it. I will try the other app shortly and then if that does not work, flip it to bridge mode and see what happens. I will let you know what comes of this....kinda a pain that it being finicky like this.......
Mark
