Robert888
Jul 06, 2020Aspirant
Nighthawk x6s ac3000 (power adaptor available with AU plug?)
Hoping someone can help? I just purchased a Nighthawk x6s ac3000 Router from eBay from America still waiting for its arrival. I have looked in the user manual to determine the power adaptor an...
- Jul 06, 2020
> I just purchased a Nighthawk x6s ac3000 Router [...]
None of that is a model number. Look for "Model" on the product
label.> Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
"R7900P" is a model number. (Is it yours?)
> [...] determined it is 19v 3.16a and 50Hz. [...]
Don't confuse input characteristics ("50Hz") with output
characteristics ("19V/3.16A"). The router cares only about the
asapter's output.> [...] I was wondering if these power adaptors can be purchased with an
> AU plug? [...]Netgear buys them; Netgear doesn't make them. You should be able to
buy one, too. Netgear doesn't sell parts.
> [...] Prefer to use original power adaptor. [...]Define "original". Same as Netgear buys? ebay.com.au?
I'd look for an adapter with the desired input characteristics and
connector, and the desired output characteristics and connector.
Seeking "original" might be a lost cause.
antinode
Jul 06, 2020Guru
label.
asapter's output.
> AU plug? [...]
